Results 1 to 5 of 5
Thread: gearshift play
    Jul 2010
    Wagga Wagga
    gearshift play
    hi fellas.
    can anyone help with what to look for to find the source of the play in the gearshift mechanism of a 1999 mk 4 golf.
    it is a really sloppy shift that has been worse since having new clutch at a dealer.
    the shifter itself doesn't seem to have too much play/wear so i'm guessing it is to do with the gearbox end of the two cables where they attach to the linkages? any one have any experience with the earlier cable shift mechanism?
    phil.
    Jul 2007
    Brissy
    Check the linkage
    Here is a vid on adjusting it
    YouTube - Volkswagen Group Shift Linkage Adjustment for year models 2000-2010
    Could also be worn linkage bushings, 42 draft designs make some nice replacements.
    VW Shifter Bushing Set - Mk4 5/6S MY02-05
    Eginne and gearbox mounts can make it hard to select gears - not sure about sloppiness though
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Apr 2008
    Be careful doing this, you might go without 5th. It took me ages and heaps of fiddling around to get it done correctly.
    2000 Mk IV GTI
    Jul 2010
    Wagga Wagga
    thanks jc
    yep...seen the vid and the bushes..don't seem to be applicable to this car....the cables don't have that three jaw,spring,knurl end....been doing lots of googl'n but can't find anything that is relevant to this style of linkage.
    yeah dubbed...i'm resisting temptation just to pull it to bits and look for something worn too much...but is starting to look like i might have to.
    Jul 2010
    Wagga Wagga
    actually, its this one, just found parts diagram.
    1998 Golf/Variant/4Motion VW Replacement Parts
    so now i know the correct name for the parts.
