Easiest way is to cut the brass clip. And if you need to reuse the knob instead of the brass clip a good cable tie will work the same. There's also no thread on the shaft.
I tried getting off the gear knob earlier and it wouldn't come off.
On closer inspection underneath there is a brass coloured metal ring holding some plastic bit.
Is there a way to get it off and maybe back on if needed?
And also is there a thread in the metal itself?
Im trying to put my dildo shifter on my car.
Thanks
Platinum Grey mkV Jetta turbo, Viezu motorsport map, GT-CX 18", lowering to come
MKIV Golf R32
BMP
#171 / 200
You shouldn't need to bust the brass clip to get the gear knob off. Take your time and you'll be able to re-use the parts.
... and nobody commented on the whole dildo shifter thing? ok, cool.
MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
Well it is Adelaide ... - to each their own yeah?![]()
Ive had this shifter for 2 years and its been on various cars I've owned. From Mazda's, Nissan's, A Datsun, Mk1 Golf. Now it needs to go on the GTI. Also I find the stock shifter too low
