Results 1 to 7 of 7
Thread: Gearknob removal help
    Mar 2012
    I tried getting off the gear knob earlier and it wouldn't come off.
    On closer inspection underneath there is a brass coloured metal ring holding some plastic bit.
    Is there a way to get it off and maybe back on if needed?
    And also is there a thread in the metal itself?
    Im trying to put my dildo shifter on my car.
    Thanks
    Aug 2009
    Easiest way is to cut the brass clip. And if you need to reuse the knob instead of the brass clip a good cable tie will work the same. There's also no thread on the shaft.
    Platinum Grey mkV Jetta turbo, Viezu motorsport map, GT-CX 18", lowering to come
    Feb 2007
    Somewhere
    Nov 2006
    Largs Bay, S.A.
    You shouldn't need to bust the brass clip to get the gear knob off. Take your time and you'll be able to re-use the parts.
    Jun 2008
    Cronulla, NSW
    ... and nobody commented on the whole dildo shifter thing? ok, cool.
    MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
    Nov 2006
    Largs Bay, S.A.
    Well it is Adelaide ... - to each their own yeah?
