Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Gearbox... hard to shift quickly?
    Sep 2007
    Mine is an 02 and I can change gears as quick as necessary (or un-necessary sometimes )
    I notice too that the throttle response is pretty poor, mainly when just blipping the throttle on a downshift.
    Quote Originally Posted by McCosker View Post
    This sounds like a problem. im my 99 GTI, i can swap gears up and down as quick as i like. if my hands could move faster i could change faster.
    Was there something different in the gear box through the year models?
    There is a slight difference in the early Mk4's. They had the shifter linkage stolen from the VR6. Not a huge difference though.
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
    Quote Originally Posted by 99gti View Post
    are the linkages able to be replaced like the later models? mines a 1999 model like yours 99gti, and was thinking i might give it a crack as well!
    sorry, trying not to hijack!
    1999 MK4 GTi 1.8T - Custom Code Stg 1, ECS Stg 1, 14lb Fly, 18" A8's
    ''Jap cars pull the G-Forces... Euro cars pull the G-Strings...''
    Quote Originally Posted by HOLEIN1 View Post
    Yes and no. On visual inspection you could with a little drilling on the shifter. Just drill out the pin that the cable conects to but I havn't attempted it. Beyond that minor difference, I'm not sure what else there is but there are other minor differences.
    i remember reading on here some time ago that the difference between the early and later models was on the gearbox end of things
    however i may be wrong....
    No, you are quite right. I have a TT shifter sitting here that has a shorter thrown than the GTI's. It would fit a newer Mk4, but no mine. I keep meaning to drill out the pin and see if it will then work, just havn't gottend around to it yet.
