Results 1 to 10 of 12
Thread: Gearbox chatter
    Sep 2008
    Townsville
    Gearbox chatter
    When i start the car cold the gearbox makes a chatter sound....... if you depress the clutch pedal then the sound goes away.
    To me this sounds like an imput shaft bearing is stuffed but a few people that have listened to it say that its either gearbox back lash and thats normal or its a VW box and they all make that sound ?
    I have had a listen to Blitzens car and if you listen really carfully you can hear a similar sound but nothing near as audible as mine. It dosnt have a dual mass flywheel anymore as i was told this will make it louder although once the box warms up the sound level decreases.
    No gears crunch,easy to shift just a concern something might get worse.
    Jun 2008
    South Coast N.S.W.
    Quote Originally Posted by kaneda View Post
    If the sound goes away when you depress the clutch then I would be more inclined to think it could be associated with your clutch pressure plate or even a thrust (throw out) or spindle bearing.
    Russ
    Russ
    2005 Subaru Outback 3.0 R Premium
    Sep 2007
    Pretty sure it's the thrust bearing, my car does the same.
    Did it when I bought it, still does it with a new clutch, flywheel and bearing.
    Sep 2008
    Townsville
    The throw out bearing isnt in operation until you press the clutch pedal so when they are shaged symtoms are the other way round ie. no sound then when you press pedal it makes a bad noise.
    Feb 2008
    nsw
    is it a new clutch? mine did it after i fitted the ecs clutch.
    a4 1.8tq,s4 mirrors,genuine,a8,wheels,black side markers,rs4 grill, apr r1 dv,neuspeed springs 2" drop waiting for haltech ecu
    Dec 2007
    Ermington, Sydney
    Mine wasn't like that mate, mine made your sound (cold and hot...) when my clutch was OUT. It was diagnosed as a buggered thrust so I replaced it and the clutch, and the noise went right away.
    My money's on throw-out.
    Sep 2008
    Townsville
    Quote Originally Posted by MIS.18T View Post
    Yes its an ecs vr6 clutch and fly wheel and i was told that this would make a bit on noise ...... I do have a replacement bearing and the sleve it sits on just not wanting to pull the box out untill im 110% sure thats what it is.
    Feb 2008
    nsw
    mine went away after afew kms, how old is it?
    Jun 2008
    South Coast N.S.W.
    The trouble with a throw out bearing is that I'm pretty sure you'll find that if they've got a bit of play in them they will still chatter or rattle even before you depress the clutch and will normally quieten down a bit once they warm up.
    Russ
    Russ
    Apr 2008
    Quick question - how hard is it to remove a gearbox in a Golf?
    2000 Mk IV GTI
