Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Gear box broken . . . . Again
    Sep 2008
    Townsville
    After having the bolts in the peliquin diff let go and finding out that they originally had the wrong ones supplied I had the gear box case replaced and new ARP bolts installed so happy days......
    Not quite because round 2 just started.
    Most of the gear box oil jumped out the other day and on removal of the gear box discovered the lovely hole in the bell housing which is the tell tale sign of diff bolt troubles
    Decided to split it this afternoon when I got home from work and this is what I found.
    Hmmm whats all this shinny silver stuff
    The hole from the inside of the case
    Im sure something is missing
    Oh wait there's the missing bits
    oops
    My spedo stopped working the other day and here I was thinking it was the sender unit (this is the gear the speedo runs off)
    Do i put it back together or bin it and start again......
    So next step ? not sure
    + hole in the case i can fix no problem
    + I need a new speedo gear and bit that goes to the sender unit
    + New bolts to hold the final drive to the diff
    + New clutch as the one in it is soaked in oil
    Anyone know if I can buy the parts I need ?or where to get them from ? or Im almost in the mood just to send it to someone to sort it out so all I have to do is whack the box back in.
    Feb 2008
    You could get the workshop who did the dodgy job in the first place to fund the repair while getting another workshop to fix it... Too bad he failed to send you a payment receipt after he repaired it the first time...
    Jul 2011
    Looks like you know what your doin!!! I'm sure you can source the parts required and put it back together yourself you would definitely save labour cost. But I fully understand where your coming from in regards to sending it out and saving you a headache rebuilding. Have you quoted what genuine parts would be???
    Jan 2011
    Gold Coast, QLD
    Just out of curiosity, is the peloquin a **** lsd?
    What caused the rapage on the speedo gear?
    If you had the right bolts the 2nd times what happened to cause the bolts to sheer off like that?
    Sorry for the 20 questions, i know bugger all about this part of the golf.
    Feb 2008
    Quote Originally Posted by Sirocco20348 View Post
    Poor workmanship... The Peloquin diff is a good product, but when it hasn't been installed properly, the above happens.
    The damage to the speedo drive gear was caused by floating bits of metal, likely the heads of the bolts, meshing between the gears and tearing them apart.
    Dec 2007
    Girraween
    Quote Originally Posted by Blitzen View Post
    Peloquins are known to shear bolts, do a search.
    Euro Revolution - eurorevolution@live.com.au
    Importing Quality Performance and Spare parts for Audi & Watercooled VW's
    New website almost up and running ... http://eurorevolution.webs.com/index.htm
    Courtney
    Sep 2008
    Townsville
    Settle Ryan or Il shorten your chain
    Yes the Diff are good and yes they are know to sheer bolts as the first lot were supplied with incorrect bolts and peloquin has addressed this issue .
    What worries me tho is the first time this happened it had the old style bolt in it which were know to sheer off but then they were replaced with the ARP super dooper fantasticle bolts that were ment to out last time itself but again failed
    Third times a charm maybe
    Oct 2010
    Melbourne, VIC
    Just out of interest, how did you know which version of the 02J Peloquin to get?
    VERY disappointing to hear that the ARP bolts sheared - were they under torqued?
    With the super high tensile bolts, this can be worse than over torque since the bolt will almost certainly shear immediately if this happens.
    Resident grumpy old fart
    Jan 2011
    Gold Coast, QLD
    Long winded rant and lend me your ears
    This is a good read! Pretty much a mechanic was taken to court and shafted for the install of a peloquin lsd, even thou he was given the dodgy bolts lol... poor bastard.
    Sep 2008
    Townsville
    I don't really want to get into "whose to blame" rather what went wrong so it dosnt happen again and pass this info on BUT quick tale while we are on the topic.......
    The first time it happened I sent it back to the shop that installed it the first time not because I was angry and wanted them to fix it for free , but they had experience in the issue and assured me they would sort it out , and they did.
    So now that it has failed when I was told it was all sorted dose all the blame go back to them ? funny thing is they didnt even fix it the last time someone else did they just didn't tell me that so if I was cranky and didnt find out that they were just the middle man of course everything would be pointed at them .
    Lesson learned
    moving on
    Anyone know where I can get replacement diff bolts ?
