Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Fuel Filter Replacement?
    Jan 2007
    Quote Originally Posted by VWEAPN View Post
    bought it from a VW new parts supplier in Moorebank, Sydney
    Got a contact number?
    Mar 2007
    sydney
    9821 5000 tell them to transfer you to moorebank spare parts
    2004 GTI, GIAC, DOWNPIPE
    2007 R32 3DR MANUAL
    2010 NAVARA D40
    2016 Q7 4M 200kw
    Feb 2008
    Auckland NZ
    ok in this step.
    Open door let fuel pump prime fuel line, then remove fuel pump relay. Open petrol cap and release pressure.
    Then remove clips from both sides of fuel filter. Have a bucket or catch can handy for excess petrol. Remove bracket from fuel filter pull old filter out.
    Put new filter in the right way around. But bracket back on connect either side of fuel filter make sure front hose is connected back on all the way till it pushes up against fuel filter. Tighten everything, re install fuel pump relay.
    Open and close door about 3 times, start car. Let it idle for around 3-4 Minutes. Then take a very gentle drive for around 1km and then you are back in business as per usual.
    Hope this helps.
    Audi S4 (2001) - Imola Yellow
    Secret Project
    Jan 2007
    Cheers mate...
    Mar 2007
    sydney
    now thats what i was after
    thanks man
    2007 R32 3DR MANUAL
    2010 NAVARA D40
    2016 Q7 4M 200kw
