9821 5000 tell them to transfer you to moorebank spare parts
80,000km 1997 MK3 VR6 manual for sale - www.vwwatercooled.org.au/forums/f23/80-000km-1997-manual-vr6-nsw-sydney-67658.html
2004 GTI, GIAC, DOWNPIPE
2007 R32 3DR MANUAL
2010 NAVARA D40
2016 Q7 4M 200kw
ok in this step.
Open door let fuel pump prime fuel line, then remove fuel pump relay. Open petrol cap and release pressure.
Then remove clips from both sides of fuel filter. Have a bucket or catch can handy for excess petrol. Remove bracket from fuel filter pull old filter out.
Put new filter in the right way around. But bracket back on connect either side of fuel filter make sure front hose is connected back on all the way till it pushes up against fuel filter. Tighten everything, re install fuel pump relay.
Open and close door about 3 times, start car. Let it idle for around 3-4 Minutes. Then take a very gentle drive for around 1km and then you are back in business as per usual.
Hope this helps.
Audi S4 (2001) - Imola Yellow
Secret Project
now thats what i was after
thanks man
2007 R32 3DR MANUAL
2010 NAVARA D40
2016 Q7 4M 200kw
