Try testing the switch with a multimeter.
If the switch is OK then maybe the problem is with the actuator at the fuel door.
Hi everyone,
another day and another problem, my fuel cap will only open when it's happy (golf iv). Sometimes it'll open when i press the button, sometimes it feels like the buttons not attached at all. Anyone know how i can fix this little nasty problem?
Any input will be appreciated thanks in advance
Switches common on them mate, disconnect it and bridge it to try and your flap will open, if you have VCDS ( VagCom) you can do an output test and that will work the actuator, that way you will know if the switch has sharted
Jmac
Alba European
Just replaced mine.
First it used to fire out and have to be reinserted then the plastic pins broke off.
Been opening it with a screw driver, relax not the fuel cap, just stick the driver into the switch there is a little pressure plate in there.
Even better just replace it it was only $22.
2003 Bora Motion - Black Magic - Still Daily
2000 Bora 4 Motion - Black- RIP
1997 Golf GL Hot Chilli Pearl - Sold
