Are you after parts or ?
hi rollerbearings stock this for my
1.8t gti mk4 1999
but no hub-just wire brush lick of paint jobby?
wheres the best place to buy these bits online dont mind waiting if OS!
links be great guys..slowly picking off the issues with gti and searching gives me a **** storm of this and that
and mechanically will end in a fisting-im capable to a degree-without a degree
*issues/suggestions- will be noted and tested and best buy links purchased.
-rocker cover gasket leak
-power steering hose leak
-fuel pump could be fritzed-brief stalls on 1/4 tank-no drama at full tank
-coolant hose to rear of engine near head leaking-fuk knows-hope no engine lift..
knock them off then power up time-got the dump pipe sorted gav..im gunnin for ya mate!
DEEP POCKETS NEEDED
Bug_racer supports the rebellion of the euro revolution
yeah parts..who do you guys mainly go through in aus/eur/china?
DEEP POCKETS NEEDED
Little parts like rocker cover gasket I get from vw or imparts (Daniel) hes my mate that works there if need be. They dont normally sell to public but I'm the exception.
Power steering hose leak could be as simple as a new hose clamp or split hose.
New fuel pump will be needed if you want more power too DW65 fuel pump I've been recommended
Coolant hose to the rear of head could need a new seal? Pics would be handy too mate
thanksguys..so much OS parts guys ..a go to reference would be great up in here..unless ive over looked a thread..anyways i will check them out![]()
DEEP POCKETS NEEDED
