Results 1 to 8 of 8
Thread: Front sway bar
    Feb 2010
    Warnervale, NSW
    Front sway bar
    Looking to replace some bushes just to refresh the front end a bit, just wondering the frotn sway bar stock size on a 2001 GTI if anyone knows?
    Cheers.
    2001 MkIV GTI
    Revo Stg 1 - K&N Intake - Forge DV
    Nov 2006
    Largs Bay, S.A.
    Not sure if it's the same across all models, but mine is (or was ) 21mm on a mk4 2.0.
    Feb 2010
    Warnervale, NSW
    I have a feeling its the 21mm, but I dont even have calipers to get under a check
    2001 MkIV GTI
    Nov 2006
    Largs Bay, S.A.
    This might help: (has front and rear)
    VWVortex.com - MKIV rear swaybar list
    Are you thinking of upgrading your front?
    Jul 2012
    I just got mine replaced and I'm pretty sure it was around 21/22mm (cant quite remember now) Mine is a 2001 GTI
    Aug 2011
    melbourne
    Blocking the lows. Mines getting the chop
    Feb 2010
    Warnervale, NSW
    I just want to replace the D bushes on it. Could someone please measure theirs on the GTI by any chance?
    2001 MkIV GTI
    Aug 2007
    I did one that had the bed spring creak so best you check the OD and then the OD where the bush sits, no doubt after you clean it itll be 1mm under. From memory the sway was 22mm and i fitted 21mm poly bushes lubed and it was whisper quiete.
    Dont just rely in the sway measurement, i would recommend measure the wear area when super cleaned
    Jmac
    Alba European
