Results 1 to 10 of 14
Thread: Front Strut Brace
    Dec 2007
    Auckland, New Zealand
    Front Strut Brace
    Hey guys looking to fit a lower strut brace on my golf. Any of you have a OEM Part number? I was told the preface lift TT had one but i can't find anything regarding this.
    1999 Golf GTi - SOLD
    2005 Golf GTI (2 Door) - SOLD
    2014 Octavia RS400 Combi
    1997 Golf GTI (Daily/Track Hack)
    Mar 2007
    sydney
    Quote Originally Posted by Fizz View Post
    yes the tt one does fit, but it does need some modding,
    i bought a neuspeed one its very good, looks hot
    mk4 the mods begin for round 2 hahahha
    May 2007
    I'd be interested to know also...
    Dec 2007
    The Strut brace to get comes off the Audi S3
    Upper strut brace 8L9 805 629 A
    Lower brace 8N0 199 403 B
    Bolts for lower brace N 104 679 01 (u need 2)
    Captive nuts N 909 147 01 (u need 2)
    Getting this ordered tomorrow and have just scored a neuspeed rear sway bar 4 $150 Now 2 get a front neuspeed sway bar Then the only thing left is urethane bushes and suspension is sorted
    Feb 2008
    New Zealand
    dude.. your going to have throttle off oversteer something chronic after all that!!!
    remember on that drive where you missed the corner and went straight ahead..
    well this time youll throttle off and your arse will swing aorund liek a pendulum..
    - 2010 Golf R
    - 1997 Golf VR6
    - 1989 MKII Golf Diesel
    - 1987 VW Golf GTI 16V
    May 2007
    Thanks FIZZ, you have gone over and above there!
    What nuts / bolts did you use to mount the upper strut brace?
    I am getting these parts priced now also...
    Glenn
    May 2007
    Quote Originally Posted by HitmanR32 View Post
    HitmanR32, I dont quite understand?
    Are you saying the above mods are no good?
    Do they upset the balance of a near factory Golf?
    Please explain...
    Glenn
    Dec 2007
    What? with the sway bar or the lower strut brace?
    I would have thought fitting front and rear sway bars would stabilise the car and u wouldn't get your springs/ shocks bunching up on the inner side taking a corner at high speed as this will keep everything nice and even
    Dec 2007
    Quote Originally Posted by ope126 View Post
    Glenn
    Just went 2 the hardware store and picked up some nuts, washers and bolts 4 the life of me i can't remember which ones i ended up with. Just make sure that they treated against rust and you use fish oil or something around the holes to prevent rusting.
    Feb 2008
    New Zealand
    Heres a thing or two about MKIV golf handling
    Put rear sway bar in you reduce traction at the rear there fore giving the front more control. this is a good thing as with a fwd you are driving with the front!.
    HOWEVER
    put to stiff and you will induce alot of oversteer which can be problematic and unexpected.. ie easing off the throttle mid corner!!! i ran a very harsh setup in my GTI but i learned to drive it and loved it! I ran ridiculously Stiff stiff stiff (custom built) bilstien shocks (this has they same effect as a sway bar in the rear of a MKIV FWD as they are a beam axle (non independant) setup in the rear!
    My GTI was capable of Drifitng around a corner thru lifting off quickly mid corner and then driving it out thru using a lower gear and pulsing the throttle... (this was in the dry and required no hand break)
    Now.. if you change the front you can improve turn in.. however if you go TOO stiff you will reduce traction from the front and increase your Understeer Problems!!! which is something you dont want in a FWD!.
    Basically in a GTI for a handling set up
    you want either extra stiff shocks for the rear. or a rear sway bar that is semi heavy! this will make you a little more suseptable to oversteer. but also reduce your understeer!
    the front i left standard sways and had bilstein b6 sports in the front for shocks! this left it firm but spongey and allowed the front wheels to feel around and grip on to what they could get hold off instead of having to lug so much of the arse end around, due to the fact that pre sway bar the rear was gripping on to the ground surface!.
    so really in a nut shell
    Stiff Rear = Less Understeer, More Oversteer
    Soft Rear = More Understeer, Little or No Oversteer
    Stiff Front = Better Turn in, More Understeer
    Soft Front = Good Turn in, Minimal Understeer
    Also you need to do your engine Mounts. No i dont mean VF ones as they are God Aweful for engines with less than 5 cylinders
    Buy oem Engine mounts that are stiffer..
    for your gear box get a V6 4 motion Gear box top mount and for the lower one get a EIP Tuning Stiffend Rubber dogbone mount. or one of my Stiffend Rubber dogbone mounts they are even tighter than the EIP ones if you want.. and still dont let Vibration to destroy the quiet experience in your cab..
    dont bother with Urethane bushes for your dog bone mounts as you will just drive your self crazy!
    also
    S3 upper Strut braces are good and offer positives..
    and i proved last night that my Rear (upper) strut brace i installed in Glidns MKIV GTI 1.8t improved steering response.. it eliminated those annoying creaks when backign out of driveways etc and really gets the car cocking its rear wheels when reversing out of drives on angles!
    - 2010 Golf R
    - 1997 Golf VR6
