Results 1 to 10 of 11
Thread: Front Brake Pads
    ACT
    Front Brake Pads
    Hi there,
    I need new front brake pads for my 2002 2.0l Bora. I ordered some from super cheap, however when I tried installing them they were the wrong ones. db1404. I returned them and they double checked and the same model kept coming up. They came with sensors which my car doesn’t have.
    Was wondering if anyone can shed any light on this? Any domestic online retailers before I look into ecs or something
    Mar 2010
    Lesmurdie
    Should be able to go into a vw dealer and they should give you the correct part number. I Will have a look on etka if you are still having problems.
    Quote Originally Posted by h3ktik View Post
    Hi there,
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    ACT
    Quote Originally Posted by Back Door Shenanigans. View Post
    thanks mate. im bout to head into repco, see if they can help.
    Erskineville, NSW
    GLS rallysport on this forum.
    better than anything SCA or repco sell. more knowledge too.
    Adelaide hills, SA
    Hi there,
    It's probably DB1401 could also be DB 1405, take the sample with you or take the picture of your old pad. I use DB1404 in my T5. I've done almost 30,000km on them and I can't see much wear. Great pads, almost no dust on the wheels. Highly recommend Bendix GCT.
    ACT
    Yeah I went and had a look. It looked like its either db1405 or another one that looked very similar in size. Can anyone confirm for me whether its db1405?
    Adelaide hills, SA
    The p/n's I quoted you are from Bendix on line catalogue, they're usually accurate.
    ACT
    this is very misleading
    my cars a 2.0 2002 model. According to that db 1401, 1405 and 1404 will fit!
    Clearly 1404 were wrong
    Adelaide hills, SA
    Yes, you need to take the old pad with you or at least the picture of it, simle enough.
    Alternativelly, go to the dealer with your VIN and they give you the right pads for your Bora.
    ACT
    cheers for your help. I'm sure someone on here could confirm which one it is seeing its a bora forum! I'm not doing the installing, a friend is, I have no clue how to get the brakes out or have any tools at home I really dont wanna go through the hassle in taking the pads out just to double check this.
