I use dodo juice gear, so gentle grey clay and born to be slippy lube. Works really well I've found! I'd think dodo juice make a few different grade clays as well, but don't quote me on it!
which clay bar /kit do you use?
I need an industrial strength one for my wifes car, her old work was a big heavy fabrication workshop that covered her paint in crud that makes it like velcro when you put a wash mitt on it :S
cheers, will look into it
Alright, just got home with some wheels, I wont say what they are, but it's looking like there's a little bit of work to be done on the rear fitment.
Here's the barrel up against the rear KW V3 reservoir. It's just hitting, not by much, but it is. So it's looking like I'll have to add camber and hopefully the bottom of the wheel will pull out enough to clear it. There's a little bit of room up top for camber so it could be done. Worst case even add a little bit of toe in, Tyres were cheap so I'm not worried about the tyre wear.
rear specs are 18x10 ET25 with about -1.5 degree of camber atm.
Alright, Got the wheels on.
Also bought 4L of Redline Lightweight Shockproof oil, and will be servicing the gearbox, diff, haldex and engine oil on Thursday.
I purchased a Sigma 35mm 1.4 Art lens which should be here tomorrow hopefully so will have to do a photoshoot soon.
That's fat! Looks good
nice! exact wheels i want!
Contemplating selling them after dubs in the square actually. If you're interested shoot me a PM.
choice aye
How come you want to sell them Josh? They look so good on your R32.
