Page 6 of 17 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 167
Thread: Foff's R32
  1. #51
    Can't wait to see new shoes on!
  2. #52
    Aug 2009
    ACT
    Cheer for the comments guys! It's slowly coming a long.
    One question, I went for a "spirited" drive the other day, and noticed afterwards that there was a slight knock/vibration in the rear end. It seems to happen when I change direction and stop/start. I jacked it up later and if I grabbed the lower control arm and shook it I could replicate the noise. I torqued all 4 arms up and took it for a drive, and it still made the noise.
    What I'm wondering is, is this just normal heim joint noise happening? Or should I be looking at another cause? Only reason I ask is because I've had the arms installed for quite a while now, Would have done easy 2-3k kms on them and they have never made that noise.
  3. #53
    I get a bit of noise from my front control arms but figured it was jut the security nut as they tend to come loose for some reason....
  4. #54
    Aug 2009
    ACT
    what do you mean by security nut Dyl?
  5. #55
    on mine it threads into the control arm, then there is a second nut (to stop it undoing which is impossible anyway) but that rattles around sometimes.
    Foff's R32-group_buy_mk4arms-jpg
    different arm, but is yours similar setup?
  6. #56
    Aug 2009
    ACT
    oh right, the arms just have a bolt and self locking nut, but it still makes a noise somewhere.
    Gonna take the car to my mates workshop and throw it on the hoist and shake some stuff to see whats moving haha.
  7. #57
    Mar 2009
    Not an issue with the spherical bearing in the control arm?
  8. #58
    Aug 2009
    ACT
    That's what I'm wondering, just that it started happening after the spirited drive.. Anyone else had a similar issue?
  9. #59
    Mar 2009
    Quote Originally Posted by ffoff View Post
    I haven't personally, maybe shoot JedR32 to see if he has?
    Maybe check your rear endlinks and swaybar bushings also??
  10. #60
    Aug 2009
    ACT
    Might give that a go, I'll make sure I check the endlinks and bushings as well, because I'm still running the oem ones.
