Page 6 of 17 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 167
Thread: Foff's R32
  1. #51
    Can't wait to see new shoes on!
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  2. #52
    Aug 2009
    ACT
    Cheer for the comments guys! It's slowly coming a long.
    One question, I went for a "spirited" drive the other day, and noticed afterwards that there was a slight knock/vibration in the rear end. It seems to happen when I change direction and stop/start. I jacked it up later and if I grabbed the lower control arm and shook it I could replicate the noise. I torqued all 4 arms up and took it for a drive, and it still made the noise.
    What I'm wondering is, is this just normal heim joint noise happening? Or should I be looking at another cause? Only reason I ask is because I've had the arms installed for quite a while now, Would have done easy 2-3k kms on them and they have never made that noise.
  3. #53
    I get a bit of noise from my front control arms but figured it was jut the security nut as they tend to come loose for some reason....
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  4. #54
    Aug 2009
    ACT
    what do you mean by security nut Dyl?
  5. #55
    on mine it threads into the control arm, then there is a second nut (to stop it undoing which is impossible anyway) but that rattles around sometimes.
    Foff's R32-group_buy_mk4arms-jpg
    different arm, but is yours similar setup?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  6. #56
    Aug 2009
    ACT
    oh right, the arms just have a bolt and self locking nut, but it still makes a noise somewhere.
    Gonna take the car to my mates workshop and throw it on the hoist and shake some stuff to see whats moving haha.
  7. #57
    Mar 2009
    Not an issue with the spherical bearing in the control arm?
  8. #58
    Aug 2009
    ACT
    That's what I'm wondering, just that it started happening after the spirited drive.. Anyone else had a similar issue?
  9. #59
    Mar 2009
    Quote Originally Posted by ffoff View Post
    I haven't personally, maybe shoot JedR32 to see if he has?
    Maybe check your rear endlinks and swaybar bushings also??
  10. #60
    Aug 2009
    ACT
    Might give that a go, I'll make sure I check the endlinks and bushings as well, because I'm still running the oem ones.
