Results 1 to 6 of 6
Thread: fluid on footrest - accelerator side????
    Jan 2008
    sorrento victoria
    g'day guys,
    i was detailing my gti the other day, when i noticed that the footrest (which is probably not really a footrest) near to the accelerator pedal has a fluid that has run down it.
    It appears to be oil, any ideas before i pull my dash out!!!!!!
    thanks guys
    Aug 2007
    Footrest is next to the clutch pedal , as the left foot is the one to be rested. Is this where you mean mate??????? Reason i ask is the clutch master cylinder is up in there and can be prone to failing.
    Have a look at all of your under bonnet levels too, to see if anything is a miss 1st.
    CHeers
    Jmac
    Jmac
    Alba European
    Dec 2007
    Brisbane, Southside...
    Are you referring to the plastic bit that rolls up into the side well and has a big plastic screw bump stop for the accelerator? I suppose it's kind of a footrest but not that comfortable.
    Could it be coming down from the steering column maybe? Unsure exactly how it works but I imagine that there could be some kind of hydraulics that have a leak???
    Removing the bits of plastic around that area as well as the plastic underneath the steering wheel isn't that hard. Just make sure you get all the screws and don't force anything too hard.
    Also a good tip for looking around under there is to move the seat back as far as you can and slide yourself in upside backwards.
    Good luck.
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    Aug 2007
    There is no fluids in there or anywhere near the steering column, only fluid anywhere near that sort of area is clutch master cylinder. I suggest looking there and make sure all the under hood fluids are good.
    Jmac
    Alba European
    Dec 2007
    Quote Originally Posted by Jmac View Post
    Jmac
    No worries Jimmy. Just thought that maybe that could be a possibility.
    Disregard my post about the steering column.
    Cheers,
    Trent
    Jan 2008
    sorrento victoria
    thanks guys i will start pulling it apart tommorrow,
    will let you know!!!
