Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: First start since my engine swap!
    Jan 2014
    Central Coast, Australia
    Planning on getting my 1.6 started today for the first time in about 6 months.
    Was going to get some coolant and some cheap crappy oil to start the car and let it idle, drain the cheap oil and replace with good oil. The last oil I put in was Shell's 5W 40 I'm pretty sure.
    Any advice, hints or tips???
    Jan 2014
    Putting the cheap oil through to heat it up and thin it out so there's no chance of any crap sitting in the sump
    Jan 2014
    Topped up the coolant and changed the oil. The car starts but stalls itself within 2 seconds which seems to me it'll be something to do with the fuel, before the engine swap the fuel pump, lines and filter were all working fine. There's ¼ of a tank which I just put in and still no start. Charged the battery the other day, put my multimeter across the battery and was reading 12.5V but when I tried starting it again everything had reset like the battery had died so had to put it on charge again. Can anyone give any suggestions? Wasn't sure whether it might need to be half full for the fuel pump or sensor to kick in?
    Dec 2012
    Sutherland Shire, Sydney
    Sounds like the battery has lost a cell, it's a lost cause really as lots of electrics will fail when the voltage drops too far
    Put your multimeter over the battery and watch the voltage while your partner turns the headlights on, I bet it will drop below 10v
    Jan 2014
    Quote Originally Posted by Martin View Post
    Turned the headlights on and it dropped to 11.8V, tried to start it again and it kicked over and stalled then a whizzing a reaching sound came from around the starter motor but not sure if ® was actually the starter or the gearbox or anything. I just want it back on the road
    Quote Originally Posted by stewart08 View Post
    Don't worry about the starter, lots of them screech like that when they disengage. I think the battery is good. Are you trying to rev the engine as you start it?
    I haven't had a 1.6 but it probably needs a throttle body alignment, if the battery has been disconnected. Google that as I don;t know that for sure.
    If it keeps stalling there's probably a big airleak somewhere, booster vac pipe would be big enough to stop it running.
    Jan 2014
    I thought the battery would be fine too, yer I've been trying to start it while revving and tried without revving but it's the same thing. Not sure what or where the throttle body is though
    Nov 2013
    Goldcoast QLD
    on the 1.6 if you take the engine cover off , you will see the intake manifold at the back of it is a pipe that leads to the air box the thorttle body connects to that on the pipe
    Jan 2014
    Googled it and I feel like an idiot for not knowing what it was but I've found a DIY on cleaning out the throttle body so I'm going to give it a go tomorrow arvo and see if she'll start. I didn't want to start pulling everything apart before I even got it back on the road...and rego's out in 3 months so wanted to spend it driving ha
    Jan 2014
    Got the throttle body out ready for cleaning, everywhere I've searched says they've used throttle body cleaner or something, would warm/hot water be a good cleaner without damaging anything?
