Originally Posted by
stewart08
Ah ok I see what you're saying, so pull out the FPR itself and cover the hole it came out of with a rag or something and if the rag gets petrol on it then there's fuel pumping up to the injectors? And by flicking the key you mean try starting it and let it try kick over then check where the FPR was? Does the fuel pump from the tank, through that black filter/canister between the coolant reservoir and wiper fluid reservoir then into the injectors?
