Results 1 to 6 of 6
Thread: Firewall wiring/tubing.
    Feb 2010
    Warnervale, NSW
    Hey guys,
    I've read a ton of DIY's and they all seem to be different to my MK4.
    Im trying to run a subwoofer power wire and some vacuum tubin for my boost gauge tomorrow, and I've had a look yesterday, AND CANNOT FIND A THING. No decent gromments in the firewall, and the rain tray is a pain in the ass. I got it off and that looks like my best option, but now the tray wont even sit back properly.
    Any suggestions for our always different AU models?
    2001 MK4 GTI for what its worth.
    Cam.
    2001 MkIV GTI
    Revo Stg 1 - K&N Intake - Forge DV
    May 2007
    Moonee Ponds
    yes, take the rain try off and on the drivers side is a black plastic box, cut a hole there use a proper grommet and seal well rain try will go back alright just push it into the seals
    Audi B4 80 Q V6 '94 Race Car !! KEGGED
    Audi B4 80 V6 Avant '94 Only one in the country that I know of !!! KEGGED
    Subaru Forester XT '06 Genome Exhaust/Car-PC/Boost Gauge/Oettingers !
    --VW Bora V6 4mo '01 Gone
    Jul 2007
    Brissy
    Yep this is an easy option.
    There is grommet on the passenger side in the rain tray as well. Just near the AC filter box, comes out behind the glove box.
    For the drivers side a hole in the plastic box is best. I ran a gauge 4 wire through there for an install.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    theres a hole on the passenger side just below the glove box. iv got a sub amp power cable and two signal wires for lights running through there no worries
    Aug 2007
    Perth, Australia
    My sub power lead goes thru there as well. Its the easiest
    1991 BMW 318is RED E30
    Nov 2006
    Brisbane Qld
    If you look near the "ski jump" thing behind the air cleaner, all the main harness from the engine bay runs through a grommet in the firewall just under it.
    This main grommet has a number of small nipples around it to pass new wires through. Just need to cut the tip off of one.
    You may have to fold the soundproofing back slightly to see all this.
    If you look under the glovebox all the wiring comes through the firewall there (up near the recirc flap).
    If you use the plenum box method then make sure its very well sealed where you put wire through as that whole thing can be submerged in water sometimes.
    PM if you are looking for: R32 rear sway bar; R32 suspension springs; Euro Headlight switches
