Is the V5 the same as the V6 auto gear box?
Looking on ecs just now for auto filter, but doesn't have v5 to choose from?
2004 VW Bora v5 Auto
Hairy_mic' custom audio build http://www.vwwatercooled.com.au/foru...ent-85117.html
Yeah, it's the /2.
If you can get me the transmission code, I can look up the part number for you.
'07 Transporter 1.9 TDI
'01 Beetle 2.0
meh went to VW dealership today for quote. they recon 7l at $44 per l . Ouch
Is there anything else that is anything similar?
Where are you located? Can be had cheaper.
You only need 5L tops.
'01 Beetle 2.0
I'm in central west nsw ( Bathurst area)
Give Tooley's Imports in Sydney a ring. Give them your VIN and they'll work out what oil and parts you need.
Their oil is the same stuff, re-branded, but almost half the price.
'01 Beetle 2.0
Any ideas what the tranny oil temp should get to? I took it hit a 30km run @ 110 km in the evening and it got to 70 degc ? Didn't seem to go any higher ( maybe in a warmer day)
Ideal temperature for checking the level is in the mid-30s off the top of my head.
I wouldn't expect it to get very hot in normal operating temperatures. I'm sure if you tried, you could force it to go a lot higher, but I recommend that you don't![]()
'01 Beetle 2.0
Yes that's the temp for checking the level, as if it was to be hotter it would expand and give a falls reading, but after a good drive you would expect temps to get higher right? I'm just concerned that I don't a thusly know the correct operating temp under normal driving conditions. I'm about to do a 3k km road trip, surly if it was too hot I would have got an error in vag com?
