Results 1 to 6 of 6
Thread: Fans on high when AC on
    Jul 2010
    Elanora Heights, Sydney
    Hi all,
    I've done a lot of work lately on my car including;
    New thermostat and housing
    New temp sensor
    Crack pipe
    New radiator
    New fan switch
    New oil cooler
    Several radiator flushes
    Fan resistor mod
    All genuine parts.
    The issue is that when my AC goes on, so do the fans, except they are on high (I can hear them clearly in the car when driving). They start at low speed very briefly when AC is turned on but go to high very quickly and then stay there.
    What can I check? I double checked my resistor wiring today and added some joiners to test cross connection but that made no difference.
    I'd love and opinions or ideas. I'm scared of burning out the fans.
    Thanks
    Christian
    Aug 2006
    Papua New Guinea
    Not sure about the Bora but in the turbo models, there is a switch, that looks like this. On the beetle it's located at a 3 way join of the upper radiator hose and two smaller hoses. If you have it, unplug it and if the fans go off, that's the problem. Hope it helps, good luck with it!
    Greg
    2002 New Beetle Turbo
    Jul 2010
    Yeah, thats the temp sensor that is in my thermostat housing. Its a bastard of a thing to reach, I'll give it a go though.
    Thanks!
    Jul 2010
    For those interested, I did some reading and searching and I found this.
    As soon as I read it, it made sense as my coolant was an inch higher than the marker (I paid no attention to it.) I removed that extra inch worth last night and on my drive in today the fans were perfect.
    So, if you get this problem, the easiest thing to check is your coolant level.
    Apr 2014
    Penrith, NSW
    great info mate. If it wasn't for your threads i would have just thought the a/c system was for "comfort only"...
    Jan 2011
    Gold Coast, QLD
    Quote Originally Posted by PranK View Post
    Great find! Very interesting
