Results 1 to 1 of 1
Thread: F96 Barometric Altitude Sensor
    Jan 2011
    Gold Coast, QLD
    As promised here is the problem I recently dealt with. It must be a part that does not fail often because I have never read about it on any forums until I actively started searching for information.
    However, this sensor is a CRITICAL part of the AGU that has a dramatic effect on air/fuel mixture if it is malfunctioning.
    **THIS PART IS ONLY ON AGU BLOCKS**
    Bosch Part No: 0280101001
    VW Part No: 853919562
    ECSTuning Part Listing
    What is it?
    F96 Barometric Altitude Sensor-f96altitudesensor2-jpg
    Where is it found?
    F96 Barometric Altitude Sensor-dscn10342-jpg
    What symptoms did I experience:
    • Shocking fuel economy - 425km
    • Top end power reduced
    • Onset of boost was minimal
    • Could not drive car around with windows down because of fuel fumes.
    I also had the following VAGCOM error:
    00528 - Barometric Pressure (Altitude) Sensor (F96) 06-00 - Signal too High
    How to test the sensor?
    Reference: quattroworld.com Forums: F96 Altitude/Barometric Pressure Sensor Information (impacts performance at higher altitudes)
    Get a decent Multi-meter and check for the following approximate values. These values taken from a known good F96 sensor. If the values are out my hundreds of ohms then it might not be registering the correct altitude and affecting maximum boost pressure. From the reference link, it seems like the ohms reading for '1 & 2' most important.
    Pins : (ohms)
    1 & 2: 1200
    1 & 3: 2610
    2 & 3: 2410
    My sensor is broken/inaccurate..what should i do
