Results 1 to 9 of 9
Thread: extended ball joints ?
    Jul 2010
    Canberra , ACT
    Hi guys ..
    We all know how lowering a mk4 does all kinds of wonderful things to the geometry which affects tye way the car behaves in cornering ..
    Im wondering if there is anything oit there for mk4s that could be used to help even the geometry of the control arms for a better steering control ..
    Basically what I found .. and I have been searching for a while .. was extended ball joints for mk2 and mk3s .. but nothing for a mk4 .. has anyome else looked into this ?
    Sam
    VW BORA 2003 V6 4Motion
    Volkswagen Golf MK3 1997 CL 1.8L
    Rammstien + Autobahn + Volkswagen = Leben !
    Apr 2011
    Berwick, Victoria
    Could always just get the thread extended/welded and run a spacer/drilled out bolt?
    R32 spindels can help fix the tie rod angles on lowered cars
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jul 2010
    Canberra , ACT
    didnt 4motion Boras come with same setup R32's ?
    Apr 2011
    Berwick, Victoria
    Quote Originally Posted by Golf-Sam View Post
    Front hub/carrier on the 4motion is the same as v5, gti, 2.0 etc
    Jul 2010
    Canberra , ACT
    Quote Originally Posted by MCiN7 View Post
    Did not know that !
    I have two brand new sets of Ingalls camber adjusters (ball joint extenders) for MK4 that are left over from old projects. You can have them for $240 a pair:
    http://www.ingallseng.com/Instructions/35655.pdf
    Send me a PM if you are keen
    nsw
    These extend the ball joint to keep you roll center high after lowering and it appears to allow camber adjustment with the slotted holes too.Roll Center/Bumpsteer Correction Kit : USRT, Usually Sideways Rally Team
    Nov 2006
    Largs Bay, S.A.
    Early Audi TT spindles and control arms are also often used to correct lowering issues.
