Results 1 to 6 of 6
Thread: ignition lock cylinder
    Jun 2014
    Brisbane, Queensland
    I wanted to replace the ignition lock cylinder and switch today. Found some good videos and here. I used the old screw driver and hammer trick but couldn't undo the shear head bolts. Any suggestions? Do I just need to bang harder and persist?
    Attached Thumbnails Attached Thumbnails ignition lock cylinder-lock-cylinder-shear-head-bolts_p2301-jpg   ignition lock cylinder-img_2280_s_l-jpg
    Adelaide hills, SA
    Don’t give up, keep trying. You can use Dremel to cut the slot in the bolts.
    Apr 2014
    Penrith, NSW
    Exactly what we used to do. Cut a slot and if it was a screw type bolt we could then use a flathead screwdriver to undo it.
    Dec 2006
    Kilsyth, VIC
    That's what I did for my last one, cut slots then had a combo of hammer and screwdriver and trying to turn. I then replaced the shear bolts with standard ones for next time around. It was a little painful, but got there in the end.
    May 2019
    Devonport Tasmania
    Use an air hammer
    Jun 2014
    Finally got there on the weekend with chisel & hammer! thanks for encouragement
    .Attachment 46885
