Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 62
Thread: Exhaust smell, down on power...
  1. #51
    Jan 2011
    Gold Coast, QLD
    Quote Originally Posted by jmcc View Post
    Is it just when it gets up to temperature? I saw something yesterday on the UK mkiv Facebook about overheating the actuator? Seems unlikely, it's built to be connected to the turbo, they had to have engineered it for heat right?
    I'm not sure exactly when it plays up, there have been so many different scenarios so far I'm confused in my mind. Every time I drive the car out does something different.
    The drive home today was much better. So close to full potential. It was boosting to 20psi. Not too bad, but still not 100%.
    I have subjected this actuator to very hot temps, I doubt it would be of concern.
    Part of me still thinks it's a boost leak. I might test it again. N75 most likely a waste of money.
  2. #52
    Mar 2017
    Yeah I didn't think it'd be likely but was worth a shot.
    Maybe the map needs tweaking?
    From what I've read a small amount of boost leak should't have a huge impact on performance? Maybe the reliance on the MAF and the narrowband 02 make it worse though. You almost need a haltech or emerald just to get enough data to properly diagnose the problem.
  3. #53
    Jan 2011
    Gold Coast, QLD
    Time for another update:
    I partially removed the cat section of the exhaust and viewed the cat from the rear. It looked clean as a whistle. I kinda regret not dropping the while section out while I was at it, but I shined a torch into it and I didn't see any congestion.
    I drove the car with the rear of the exhaust removed and ut drive exactly the same, except was very loud as expected.
    Still no codes from the ecu...
    In the interim I have ordered a fuel pressure tester. I always wanted to check the pressure anyway.
  4. #54
    Jan 2011
    Gold Coast, QLD
    Fuel pressure testing:
    I received my kit and I only tested idle pressure atm as I don't have a way of viewing the gauge while I am on boost.
    "The 1.8T fuel system has a base fuel pressure of 58Psi (Approx. 4Bar).
    This is the value seen when the vacuum line is disconnected from the FPR.
    Vacuum at idle will cause fuel pressure to sit closer to 50Psi or 3.5Bar."
    This is what exactly what I observed.
  5. #55
    Jan 2011
    Gold Coast, QLD
    MAF observations:
    I purchased a brand new bosch MAF about 2 years ago. It solved my problem as my previous MAF was completely stuffed.
    However, I was reading a thread on audi-sport.net, https://www.audi-sport.net/xf/thread...109831/page-12
    This guy is mentioning the exact same problem as me (AGU block) and it ended up being his already replaced MAF?!?!
    Exact thread post talking about his solution Prawn and BigAls A3 Track Car
    Here is a vagcom log of my current bosch MAF... do the values seem excessively high for a k03s turbo? I always thought I had exceptional MAF values because it was a brand new MAF.
    Exhaust smell, down on power...-maf-testing-jpg
    I do not really want to buy a new MAF if it doesn't solve my problem.
    IS THERE ANYONE IN THE BRISBANE/GOLD COAST AREA THAT WILL HELP ME BY LETTING ME SWAP OVER THEIR WORKING MAF TO TEST IN MY VEHICLE. Please....
    Even if someone is interstate and have a spare one lying around I will pay for postage to and from and ill give you something for your help.
  6. #56
    Jan 2011
    Gold Coast, QLD
    MAF update:
    VW don't sell new MAF sensors as of 2012.
    The part number 037906461C was superseded by 037906461CX. The X denotes it's a exchanged item.
    So it's someone's old ****ty MAF that has been 'refurbished'. What ever that involves, the guy at VW doesn't know exactly.
    The dealer wants $498 for a refurbished MAF sensor, plus they want my MAF to refurbish.
    I replaced mine 2 years ago with a brand new Bosch 0280217117 MAF.
    I don't understand why VW is concerned with refurbishing MAF sensors, if Bosch makes them new?!?
    I wonder if there is an actual difference in quality between the 2 parts....
    Here is a picture of the actual sensor part number in my 0280217117 Bosch MAF.
    It would be interesting to compare the sensor numbers in a original MAF...alas I threw mine out 2 years ago.
    Anyone have a busted one they want to check out the sensor number for me?
  7. #57
    Jan 2011
    Gold Coast, QLD
    The Bosch 0280217117 is the replacement for Bosch 0986280201....I wonder if it's a refurb... To be continued
  8. #58
    Quote Originally Posted by Sirocco20348 View Post
    MAF observations:
    180g/s is supposed to equate to 225hp at the crank. So i'd say its not far off. Might be a little late in the rev range, Which could indicate a soft actuator.
    I fix a lot of mk6 gtis by tweaking actuators, lazy spool up. Can make 20kw difference if it's really a really bad one.
  9. #59
    Jan 2011
    Gold Coast, QLD
    I feel confident enough to mark this thread as SOLVED. Thanks to everyone that replied to the thread and supplied information. I am going to give credit to Gavin (h100vw) for pointing me in the direction of the wastegate actuator.
    I have full history of this Ko3s turbo as I bought it brand new and it now has 40,000kms on it. My car was originally set to 3 turns of the actuator locking nuts. Which gave me wastegate cracking pressure of 3PSI.
    I originally tried to add tightness by using some external springs as per the Spring Mod on VWVortex. VWVortex.com - Wastegate Actuator Spring Mod
    After countless times going back and forward to Bunnings, i concluded that this mod has minimal worth. People claimed to achieve wild cracking pressures by doing this. But even with the springs that I finally used which were tight (..however overextended the working range of the extension spring) I only ever got approx 1 extra PSI of tightness. Maybe I was doing something wrong.
    So spring mod jumped the cracking pressure upto 4PSI, However I could already feel a positive difference with the car with the car coming onto boost sooner and higher WOT boost.
    I unwound the tightening nuts, reset the waste gate into a closed position and ultimately tightened it up 4.75 turns with the addition of my spring mod. (I experimented many times with increasing the nut from 3 turns upto 4.75 turns (1/4 turn increments) with the spring attached) Many late nights...
    4.75 turns and spring mod gave me a cracking pressure of approx 5.5-6psi. My car is now spooling up to 22psi psi and is back to being what I remember.
    I took my car for a drive yesterday (WOT in 2nd, 3rd and it was the same fun I used to have in the car with 22psi bumping in every gear. I logged in vagcom, and its still registering a rich mix. But my friend driving behind me was saying there was no black smoke from my car at any time.
    I also replaced the 02 sensor after all this was done and I felt as thou my partial throttle boosting was smoother. Not very technical testing. On the AGU the o2 sensor is a critical part of the ecu calculations and i bought a brand new Bosch sensor for $100 off ebay and took minimal time to install on my aftermarket dump pipe. This is the one I bought.
    Genuine BOSCH Oxygen Sensor 0258005081 | eBay
  10. #60
    Mar 2017
    Congratulations! You made it.
