Page 1 of 7 123 ... LastLast
Results 1 to 10 of 62
Thread: Exhaust smell, down on power...
    Jan 2011
    Gold Coast, QLD
    1.8T AGU Stage 2 down on power: Exhaust smell, 15psi max at WOT
    SOLVED:
    Hey guys, I've reached another milestone problem.
    I have two symptoms to work from.
    Exhaust smell when driving, also I am down on power at wide open throttle, the car is not reaching maximum boost. The higher the gear the more noticeable the power loss.
    I have boost leak tested the car and there is a faint hiss coming from somewhere, But doesn't seem to be a hose.
    TLDR UPDATE:
    • Hiss was identified as leaking injector seals and injector cups via boost leak test with soapy water. Replaced with aluminium injector cups and slightly bigger o-rings. This did not solve lack of power.
    • Brand new set of Bosch injectors. Fuel rate must have been limited. See final post.
    • Tightening of waste gate with helper springs holds power, not sure if essential. 6psi cracking.
    Read the thread for the full journey...
    Jan 2011
    Gold Coast, QLD
    I did some vagcom testing last night.
    Firstly no errors in engine module.
    However, I logged banks 002, 007, 008 during some 3rd gear wot runs to 7000rpm.
    Valve duty was consistently 99.5%, which indicates a boost leak somewhere in the system.
    Super frustrating, I'll be keenly interested to see where this mongrel leak is, it's not obvious.
    Mar 2017
    I might go log these blocks on mine.
    Good luck searching, boost leaks are such a pain.
    Jan 2011
    Gold Coast, QLD
    Quote Originally Posted by jmcc View Post
    I'll post up my results so you know what your looking for tonight.
    Jan 2011
    Gold Coast, QLD
    Linked is my logs...
    https://1drv.ms/x/s!ArCKuFTQ_s3egZ0Yl261TOHF9VXbog
    Group 002 has my idle speed... colour coded for ease of viewing.
    Group 007 has the valve duty... always 99.5% throughout the rev range.
    Anyone else notice anything interesting?
    Jan 2011
    Gold Coast, QLD
    Update: I had my car smoke tested for misc leaks. One was detected/fixed and improved performance. But unfortunately my car still cannot reach requested boost and my car still stinks of fumes...
    Has anyone had the 3 turbo bolts come loose?
    I am reading a thread where they come loose all the time for various people, especially when modded parts are introduced and vibrations are increased.
    This thread!! :
    VWVortex.com - TURBO TO MANI Bolts coming loose??
    When I put my hand down next to that gasket when cold I totally feel like there is air escaping from that gasket, but it's such a pain in the ass to tighten those bolts. I will have to remove the charge pipe...
    Please anyone chime in with their 5c worth.
    Dec 2008
    Sydney/Canberra
    Yeah, totally plausible.
    You'd have to at least replace the gasket and bolts. Given the age, they'd probably break if you re-torqued them, and the gasket has probably blown out anyway.
    As for a solution, high-temp Loctite seems like it'll do the job.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jan 2011
    Gold Coast, QLD
    Quote Originally Posted by Umai Naa!! View Post
    Well the turbo was a new install about 45,000km ago with all new hardware. Do you think I could give tightening a go?
    As for thread locker, which one is appropriate for turbos?
    Maybe I should just buy one of those fancy ninja stars/ turbo locking flange if needed
    034Motorsport - 034-R01-8005 - K03/K04 Turbo Locking Flange - priced each
    Mar 2017
    I don't think there's any version of loctite that will work on an exhaust manifold, even ultra high temp is only like 350c.
    You could use lockwire or locking bolts they're a pain though. I don't get how the ninja star works, seems like it'd just be a fancy washer. That bolt closest to the block is the worst to get to even under the best circumstances.
    Dec 2008
    Sydney/Canberra
    Look into tab washers.
    You bend one tab over the hex of the fastner, and the other over the edge of the flange.
    '01 Beetle 2.0
