maybe, get one of those household carbon monoxide sensors? If you've got exhaust leaking out that should pick it up.
something like this New Carbon Monoxide Meter with CO Gas Tester Monitor Detector Gauge 1000ppm I9N2 714424467812 | eBay
Tbh I just finished pulling off the charge pipe and testing the bolts, they are not loose at all, easily exceed the torque requirements.
I honestly have no idea... All I'm thinking of doing is replacing all the gaskets associated with turbo and exhaust manifold....
Maybe I wait until the subframe is dropped out for all of them as I don't know how anyone has room to get to the exhaust manifold bolts...
This looks pretty cool.. I might buy one to see if it's accurate. Would be good if it came with an extendable neck...
I have bought seafoam as a test, apparently billows snow from exhaust leaks..
I'm thinking the turbo and manifold needs to be removed and inspected very carefully for problems...
Farout I'm almost over owning this car... Replaced turbo to manifold gasket. Old gasket was fine and the bolts were tight.
That strong exhaust smell is still present at WOT.. maxing out at 15psi. Very unimpressive for stage 2.
I'm thinking of replacing the brake booster line as it's been patched up over time.
Apart from that I'm not sure... Heaps of threads on the internet with mystery boost leak problems.
Sent from my LG-H870DS using Tapatalk
What about manifold to cylinder head?
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Where is the cat in your downpipe? Had a Polo recently that was going well and then wouldn't make boost. Messed around looking for leaks. Last ditch guess and I found the cat had broken down and was blocking the exhaust.
Drive SPM | MK4 GTI Downpipe Street Kit
Mine is a separate section that looks like it could be easily inspected.
What other symptoms was the polo showing? Strong exhaust smells when driving?
I had a night to think about this and I think you might be 100% on point.
Gav, so the cat was Broken down but stayed within the cat housing? Our did it flow further down the exhaust?
I also have this insane metallic rattle at like 2800rpm. If I hold out at this rpm, sounds like a hammer drill drilling into concrete. This only started after my exhaust was secured into place.
And snapping those photos, we only have a pre cat 02 sensor, so if the cat was stuffed we wouldn't pull any codes with vagcom, correct?
Damn I'm getting excited
