Results 1 to 10 of 14
Thread: Exhaust
    Jun 2007
    Dirty West!
    Exhaust
    Ive been trying to understand what i want to put on my car, rather than someone simply putting it on. But im a bit confused between whether to get a stainless steel downpipe or mild steel but ceramic coated?
    What do others have and how do they perform?
    Thanks!
    gpk_gti Guest
    hey mate!
    whats the exact mods you are running???? before I try to direct you..
    ive got a 2 3/4 inch ceramic coated downpipe which keeps the heat in(better supposedly!) did I notice a difference,hard to tell because I had the stock pipe before,so difference between SS and this,well who knows...
    Jun 2007
    Dirty West!
    Im only running an oettinger chip with a GFB BOV. I was also told that ceramic coated draws far more heat than stainless steel and its not prone to fracture under extreme stress...?
    Nov 2006
    Quote Originally Posted by shami View Post
    From what I've read - The difference is marginal.
    Ceremic is best used with extractors because they sit in the enginebay relatively close to the air intake, but otherwise - Its abit of a wank.
    gpk_gti Guest
    I would be doing the cat back first and then doing the dump pipe.its not such a restricted pipe to be so concerned about it.maybe on ricers its a must do,but the gti?I wouldnt have bothered but the price I got was a mates rate so ceramic or not didnt concern me(you are right sov).
    why dont you look at getting a TIP first and airfilter where you will notice a HUGE difference???
    hey sov! did you get your car back yet???
    Nov 2006
    Quote Originally Posted by gpk_gti View Post
    Back on the road shortly (2 weeks)
    Sorry George, got to disagree about he down pipe. The std one is weedy and full of clearance dents making the problem worse. A change to a mandrel bent one makes a big difference in spool up.
    A mate of mine in the UK has a 2.5 inch one mated to the std system (he commutes about 100 miles a day) and rates it a better mod than having an exhaust done. He has been in lots of chipped A3/GTIs.
    I have a 3 inch on mine which fits and doesn't touch anything.
    The std exhausts flow pretty good to be honest.
    The TIP on the other hand is a top move and a TIP and downpipe would be the first mods, I'd be doing if money was tight.
    I have the std A3 system in the shed, I'll get you a picture of the DP.
    3 inches of joy
    http://www.imagestation.com/4216216/3938200498
    more of the sport cat.
    http://www.imagestation.com/4216216/3938200104
    some shots of the A3 and exhaust and other stuff
    http://www.imagestation.com/album/in...?id=2098388197
    std down pipe
    std DP is 2 inch
    Exhaust is 2.25 inches
    The restriction has to be in the smallest diameter pipe.
    Last picture
    gpk_gti Guest
    suppose you are right gavin,I should have done dump pipe by itself to assertain what power it gave just itself,but being a little impatient I got the whole exhaust done at the same time..Maybe shami could do it seperately and tell us what the benefit was???
    how much power gain you think the dump pipe gives gavin?
    Ultimately the power is determined by the boost, which is requested by the chip.
    The gain from the down pipe as I see it is in the ability for the turbo to spool up quicker due to less restriction down stream.
    This would give you more area under the curve, which really means a more flexible car to drive.
    It may be with a custom map that you could get more power.
