Results 1 to 10 of 11
Thread: Exhaust
    Aug 2008
    Exhaust
    As you know I have recently bought a MKIV R32, Was flicking through the brochure that was still in the car and I saw these two silver things that I think they are called exhausts My car didn't have them when I bought it, just two tail pipes that were very very dirty that you could hardly call exhausts. I have found after many washes that inside the exhausts, it is still very dirty no matter how hard I spray, scrub, wash etc. Does anyone know how I can fix this problem or what chemicals to use so that I can get my R exhausts back to brochure/showroom condition?
    Thanks
    Tom
    .:MKIV R32:.
    .:Reflex Silver:.
    .:80th of 200:.
    Apr 2008
    How about a metal polish such as Autosol?
    2000 Mk IV GTI
    May 2007
    Moonee Ponds
    ... I just clean inside mine but don't bother to much. I guess you know that everything the engine doesn't burn gets thrown out the exhausts ?
    You could try a wire brush or some sandpaper to get rid of the buildup. But it might scratch.
    Jan 2008
    could try some throttle body cleaner to clear the carbon deposits from the inside. Be careful not to get it on your paintwork though!
    Then as said above; autosol is awesome metal polish.
    Feb 2008
    Brake Clean will get it clean...Just watch your skin...It will dry it out like a bitch!!
    Aug 2007
    Perth, Australia
    i was wondering how to do that too. Thanks guys
    1991 BMW 318is RED E30
    Sep 2007
    If the outside of the pipe is dirty/oxidised, I use one of the Mothers Powerball mini's and Autosol. Works a treat and easy on the hands too!
    http://www.mothers.com/02_products/05141.html
    Dec 2007
    Brisbane, Southside...
    Steel wool, water, detergent and some elbow grease. That's all you need. Don't worry about the steel wool damaging your exhaust, it won't.
    Also some brite shine wool metal cleaner which you can get from autobahn or the like will help you out.
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    Jan 2008
    brite shine's acidic isn't it? usually for aluminium i thought? supercheap sells it too.
    Aug 2008
    thanks guys,
    I will try a few of these methods until it works. Will make sure I get a before and after shot aswell
    .:MKIV R32:.
    .:Reflex Silver:.
    .:80th of 200:.
