Results 1 to 10 of 18
Thread: R32 Fluid Change
ranton-inc R32 Fluid Change 20-08-2008, 08:33 AM
torque that castrol is too thick...... 21-08-2008, 12:46 AM
ranton-inc The Castrol is fine... Ive... 21-08-2008, 10:00 PM
torque I got redline MTL in my MK4... 21-08-2008, 10:29 PM
Jmac Penrite 5HPR is good for... 22-08-2008, 12:00 AM
    Feb 2008
    New Zealand
    R32 Fluid Change
    So... Where to Start
    Its time for a Fluid Change again in the R
    Now I had the Haldex done and the Filter done last time around when i had the oil and filter done!
    I wish to do the Gear box and Rear Differential
    Who has had their Fluid Changed in these and what fluid do they reccomend.. i read a few mentions of Redline MTL etc
    over here the genuine vw stuff is about 60 bucks a quart/litre
    Who has used what in theirs and how have they felt, differences etc?
    Also what quantities..?
    For my Engines i always use Castrol Edge 10w60 full synthetic with a new filter and flush every 8,000kms
    - 2010 Golf R
    - 1997 Golf VR6
    - 1989 MKII Golf Diesel
    - 1987 VW Golf GTI 16V
    Nov 2007
    Melbourne, Australia
    Quote Originally Posted by HitmanR32 View Post
    that castrol is too thick... but redline MTL I can vouch for that. Excellent.
    check redline recommendations for car there is a script @ their website
    2001 Audi A3 1.8T manual | Giac stage 1 | 3" custom down pipe |TT brake carriers and disks | Eibach pro kit | S3 wheels |APR R1 valve
    2002 BMW M3 6sp manual | Macht Schnell stage 1 intake | Rogue Engineering power pulleys | CSL OEM Wheels | Rear LED lights
    Feb 2008
    New Zealand
    Ive been told to use VW only Fluids when it comes to gearboxes etc.
    but in terms of how the gearbox reacted since the last fluid change.. if anything the fluid change made it worse.. im wondering if the Stealership put the wrong fluid in...
    its shifting like a peice of crap..well in my opinion it is any way.
    - 2010 Golf R
    - 1997 Golf VR6
    Nov 2007
    I got redline MTL in my MK4 and the shift got better at cold... The reverse does not seem so noisy as before so it got better. I could say much better ...
    I thought 60 is too thick for when it is hot... I believe the Oils VW recommends are in the 40 range ?
    Aug 2007
    Penrite 5HPR is good for the.:R mate, and Redline MTL as always i fully recommend, does make the box quieter and due to its friction properties makes the shift a lot better. By the way i worked for Dub for over 10 yrs in the one dealership and around 5 in others and mate the oil coming out of the nozzle was always changing depending on the going rate. In the Uk for Dubs we used Shell Helix and Rimula for the older stuff. What you will get out of the pump in most here is 5W40 mate and generally is Castrol. As for the new diesels you will use Castrol SLX some 0W being used too. The new stuff i stay quite tight to the guidelines as ive seen dramas with variable valve timing if the viscosity is wrong.
    Cheers mate and as you know everyone has their preferences and there is a lot of good quality oils out there. Makes it hard and some way over priced.
    Jmac
    Alba European
    Feb 2008
    New Zealand
    well ill give the MTL a whack cos my Cold shifting is especially sucky!!!!
    being brrrrrr cold nz and all lol
    I need 3 litres for the gearbox and prolly 2 litres for the rear differential hopefully it quietens thta up too!
    i havent had any qualms with my MKIVs and running them on 10w60 my GTI recieved absolute death day in and day out.. 70,000kms it showed little sign of wear
    - 2010 Golf R
    - 1997 Golf VR6
