With 18x8 +35 you would be safe with 225/40/r18 at a decent height, seeing yours is stock you will have no problem.
F ET20, R ET15 215/40/R18x8:
http://www.vwwatercooled.org.au/foru...tml#post725083
most guys get a 18x8et35 with a 225/40.
Silver dub and I both ran 19x8.5et35. we both JUST sat outside the guards at a 30-40mm drop, but mine lowered down to 50-60mm it tucked right in.
so height makes a big difference.
yeah i was refering to the orginal post of 17x8et20 and 17x9et25, thanks. it wouldnt be crazy poke, but you would definatly need some form of lowering to make it work.
matt is right on the money. his car is a good example, the more he lowers it the more spacers (more agressive offset) is being applied to his wheels.
On a stock height car stick to something like 18x8et35, on a extremely lowered mk4 you can almost tuck 18x9s on stock guards
Have a look around at specs other people are running. look at the cars height, tyre size, wheel width and offset and find something that matches what you want.
Current: 01 Mk4 GTi | Milltek | 18 x 8 CH (Rep) - 09 Hypermotard 1100S
Gone but not forgotten: 01 Monster 900Sie - 01 CV8 - 71 MGB - 99 WRX - 67 MGB - 76 Mk1 LS x 2
if the camber bothers you, I'm sure theres a camber kit out there to suit.
be cheaper in the long run if you plan to wear out tyres
2007 Audi RS4 with: APR ECU Upgrade; JHM Quick Shifter; Milltek Catback and Downpipes; KW V3 Coilovers; Argon Creative Carbon Fibre Splitters
i'm probably ordering some from bm or another place on ebay that has some 18x8 +35 bbs rs reps that i think would look mad. remember to take VAT tax off (17.5%)
thought about bbs ch reps but really want dish![]()
Platinum Grey mkV Jetta turbo, Viezu motorsport map, GT-CX 18", lowering to come
