Righto
Theres 7 ,10mm nuts that hold the 2 engine covers ontop of the engine. undo these and remove the covers.
First. If you look at the intake pipe there should be a ( approx ) 50mm bit of hose that joins onto it from the oil filler neck.
There should also be another hose that comes off the oil filler neck and comes down and joins onto the crank case. check to see if these are broken (VERY COMMON )
Also, if your standing infront of the engine bay on the right hand side of the block, there'll be a black coolant block that has 4 outlets on it. There'll be a coolant sensor on the top. Check to see if the colour of the top section is black or green. If its black, get a new one ( is a known VW problem to fail ).
Start the vehicle and spray carby clean over all vaccum lines in the engine bay. ( this is to find any leaks, if the revs drop then pick up you know you've found a leak )
Maybe try removing the fuel filter and removing the contents onto a white rag. ( if there are any contaminets in the system they will show prominetly on the rag. Ive used this technique of Golf 4's before )
Failing those suggestions,
You could go to someone with a scan tool. It doesnt need to be a dealership, just any workshop that has a OBD-II compatible tool with the ability to read VW systems ( it just helps to go to a dealership as the techs have most probably seen the fault before and have all the information within easy reach/ can fix it really quickly )
Hope this helps
![Smile](https://www.vwwatercooled.com.au/forums/images/smilies/icon_smile.gif)
