Results 1 to 10 of 10
Thread: Erratic Coolant Temp Gauge
    May 2007
    Jimboomba. QLD
    Hi Everyone,
    A while ago I posted a thread regarding what was normal in regard to the coolant temp gauge in my Mk IV (1.6)
    I thought I had fixed the problem by cleaning the terminals on the temp sender unit....but the problem is back.
    On most occassions, the temp gauge reads fine, but then the needle slowly drops away to read almost nothing on the gauge....and then for no apparent reason, the needle climbs back up to read normally. This can fluctuate like this all trip or it might read normally all day.
    Any suggestions, is there a way of testing the sender unit, and if I were to decide to simply replace it, is there anywhere in Brisbane who sells VW parts other than the local VW Stealer
    Thanks for your help
    gpk_gti Guest
    Id be changing the sender unit.its the one that sits on the side of the thermostat housing,what colour is yours?? wonder if there is a dif on the 1.6?
    Sep 2008
    Launceston
    I've just started having this same problem. What did it end up being? coolant temp sensor?
    Apr 2006
    Hobart,Tas
    Its infuriating when people get on here asking for fixes and then dont tell of the outcome. I tend to not offer advice in the future for them when they do that.
    ntails, 99% of the time its the temperature sender unit and its a less than 5 min. job to change it mate.
    Cheers, Andrew
    Sep 2008
    Launceston
    Thanks heaps Andrew, will give Jacksons a call today and get one.
    Apr 2006
    Hobart,Tas
    No probs mate, price variesw from month to month but expect it to be anywhere from $42- $55. Best to get genuine, I always use the original and they come with a 12 month warrantee.
    Northern Beaches
    Im getting the same problem Does any one know where to get Temp Sensor from?
    Thank you in advance,
    Jeff
    Feb 2008
    nsw
    Quote Originally Posted by VDUB-BUD View Post
    Jeff
    bill buckle. have heaps.
    a4 1.8tq,s4 mirrors,genuine,a8,wheels,black side markers,rs4 grill, apr r1 dv,neuspeed springs 2" drop waiting for haltech ecu
    Sep 2008
    Launceston
    As i stated above i had the same problem, so i purchased a new sensor ($70 from VW here in Launceston). Before i could fit it though it went back to normal. Will probably stuff up again sometime, so atleast i'll have a sensor ready when it does.
    Feb 2008
    nsw
    Jeff
    ask for this
    Green Top Coolant Sensor:
    Sensor: 059 919 501 A
    O Ring: N 903 168 02
    Retaining Clip: 032 121 142
