A bit hard to tell from here.
A lot of VW boxes have issues with diff crown wheel rivets shearing. Lots of strange noises when this happens.
Need some suggestions on what could be the cause of my gearbox issues
The Problem: There is a lot of resistance when trying to change gears. To the point that I need to really force it in to gear by pressing hard on the shifter. This happens from neutral to 1st, 1st to 2nd, 2nd to 3rd, but isn't really an issue shifting to higher gears, or when downshifting.
When I push the clutch in when rolling, or change gears and release the clutch, there is a loud 'clunking' sound.
Reasons why I don't think its the clutch: The clutch is not 'slipping' at all, and hill starts etc are perfectly fine, except for the resistance when shifting. When its in gear, the drive is very smooth and as normal
What I think it might be (from reading the forum previous posts): Dogbone mount, gearbox mount, engine mount?? Anyone have any ideas to point me in the right direction?
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
How does the clutch pedal feel?
'07 Transporter 1.9 TDI
'01 Beetle 2.0
Thanks for the replies. I will be taking the car into the shop sometime this week but just wanted to get suggestions so I can look into it beforehand.
Clutch pedal feels the same as always has for me. Although another user of the car mentioned the pedal 'stuck' halfway on one or two occassions when they were driving it, and they had to pull it back up (master or slave cylinder?). Was going to look into this myself but found out the slave cylinder is located inside the bell housing.
Well, found out what it is today. Clutch pedal pushed straight to the floor, wont spring back.
The metal tab on the clutch pedal. Pull out pedal box and get a welder.
This is probably the best scenario you could have wished for actually. I got mine sorted for about $120 (after the free tow)
MK4 GTI - Sold
Throw out bearing
What kind of noises would you expect for a gearbox that has sheared the diff crown wheel rivets?
Mine has a very sporadic clunking noise that comes and goes. It sounds like metal clunking away - sometimes it's rotational - other times it's more like rubbing. Funny because you can drive for ages with nothing, other times it just comes out from the middle of no where. Seems to sound like it's coming from the centre of the car.
My rear diff is currently defunct, so I'm wondering if it's the tail shaft clunking from it trying to be turned but the diff not engaging.
Is my front diff ****ed?
Originally Posted by MightyCarMods
-| "Laura" - 2001 Bora 4-motion (now sold) |-
What is wrong with the rear diff?
NFI. Just stopped working. I've got a spare one I took out of a wreck for $100, but god knows if it'll work. I've had it sitting around for the last 6 months in the shed.
Vagcom tells me:
00526 - Brake Light Switch-F
27-10 - Implausible signal - Intermittent
01155 - Clutch
04-10 - Mechanical Malfunction - Intermittent.
Yeah, the cun,ts f,ucked. I think it's the precharge pump. Which is only a measely $500 to buy online....
