Results 1 to 7 of 7
Thread: Engine cuts out while driving after serpentine belt change
    May 2015
    Brisbane, Australia
    Hi guys.
    Hoping for some of your wisdom.
    My serpentine belt was replaced by a mechanic on Friday.
    Now the engine cuts out while driving.
    Lights, dash, windows etc. are fine, but power steering goes off too.
    Once it cuts out, it will roll over but not start. After about 30 mins to an hour it will start again.
    From what I have read, the serpentine belt powers the alternator, water pump, power steering etc. in late mk4 golfs (mine is 2003).
    Therefore, I suspect the serpentine belt is not functioning properly.
    I'm on the other side of town to the car now so I can't do much to eliminate coil packs as a possibility.
    I cleaned the MAF and replaced the battery a couple of months ago.
    Similar threads (1 2) don't seem to contain any answers.
    What do you all think? Anyone had a similar experience?
    Cheers,
    Oliver
    2003 Golf GTI 1.8t
    how long driving before it cuts out?
    May 2015
    Brisbane, Australia
    First time it would have been about 5 - 10 mins. Second time I let it idle for 10 minutes or so, then was able to drive for about a minute. I was in the middle of a heavy traffic area, so after that, it went on the tow truck haha.
    2003 Golf GTI 1.8t
    a wild guess maybe a cam angle sensor or engine speed sensor or a sensor similar has gone bust or got damaged while the car was getting serviced?
    I noticed in one of the links you posted someone suggested similar.
    Any chance someone can scan it for faults for you?
    Dec 2008
    Sydney/Canberra
    Sounds like an engine speed sensor.
    Get it scanned. It should show up as a fault code.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    May 2015
    Brisbane, Australia
    Thanks guys. Its back in the shop tomorrow for a scan. Those engine speed sensors aren't cheap are they!
    2003 Golf GTI 1.8t
    May 2015
    Brisbane, Australia
    Yep - you guys were right. Engine speed sensor. Cheers.
    2003 Golf GTI 1.8t
