Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: engine bay fuse box in a new beetle. ????
    ipswich qld
    Ok since I pulled the fuse box out to see how damaged it was the outside temp guage doesn't work. Any ideas? And also are both mirrors suposed to move when I set the drivers side mirror?
    May 2010
    Yes both mirrors are supposed to move. Someone on here mentioned before that you can program it out but I quite like it.
    On a GTI the sensor for the outside temp is on the passenger side front bumper grille. Not sure in a beetle. Maybe locate it and check that it works.
    Mk IV Golf GTI - BMP - GIAC chip, R32 wheels, KW coilovers, rear swaybar.
    Originally Posted by JoeVR
    I've never been a big fan of rotors, or really Japanese cars in general, so my choice would have to be..... an RX-8.
    ipswich qld
    I found it but unsure as to how I can go about testing it. I might just disconnect the battery and see what happens
    May 2010
    Quote Originally Posted by lilcrash View Post
    So did the outside temp guage work before you disconnected the fuse box?
    Also hasve you put a fuse in so that the fan control module works?
    ipswich qld
    The temp guage worked before and I've put a fuse in and the fan still doesn't work or it hasn't got hot enough to work. And the oil light is telling me the sensor isn't working now.
