Results 1 to 7 of 7
Thread: End Links
    Oct 2014
    New South Wales
    End Links
    Hey guys!
    Just installed a set of FK coilovers onto my Mk4!
    All went well, except, now my sway bar is rubbing...
    As most people know, FK coilovers do come with end links (see picture) , but they look enourmous.
    As you can see, the drop links which come with the coilovers are much different to whats actually on my Mk4
    Will the FK end links actually fit? because they look way too long.
    (Yes i've tried googling this and i haven't found any information on the FK end links, just people buying new sway bars and adjustable links)
    Attached Thumbnails Attached Thumbnails End Links-fk-jpg   End Links-end-link-jpg
    Mk4 2.0 Sport Owner
    P-Plater
    2.0 stock 4 u
    Jul 2011
    Longer links are for the 4motion set up
    Jan 2014
    Adelaide, East Side
    End Links
    Any type of adjustable links don't work. I've tried and failed haha
    There is no way around the stock swaybar because it is such a terrible design
    I was told a few times before I bought the links that they won't work, but thought I'd give them a go anyway
    Don't waste your money on them haha
    I've tried messing around with the height of them and also shaving part of the swaybar with a grinder
    It's slightly better but has also something to do with me raising the car 10mm aswel
    Either raise your car, cut the swaybar out or go aftermarket
    I've just bought myself an aftermarket bar because I don't wanna drive around without one haha
    I will update my build thread once it's in End Links
    __________________________________________________ ______
    MK4 GTI - Reflex Silver - <<<Click for Build!<<<
    -Previously Owned a MK4 1.6L Golf - Reflex Silver
    Jun 2011
    Car handles better without a front sway bar. Provided you don't have a huge rear
    the one pictured is a 4motion bar as said above.
    if you are lowering your mk4 enough to rub sway bar, then you are going backwards handling wise, might as well pull it out
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Jan 2014
    Narangba QLD
    Nathan you should cut yours out and do a direct comparison review as I know you were a bit hesitant to just remove it but now you have a new one to go in.
    Albury, NSW Australia
    I bought a set of whiteline adjustable swaybar links. Worked great until they snapped. I've since replaced them with OEM plastic links.
    Don't drive without a bar - Makes the car feel very mushy.
    79 MK1 GLD
    03 MK4 GTI
    94 993 Carrera
