Results 1 to 3 of 3
Thread: Eibach springs
    May 2009
    Canberra
    Eibach springs
    Hi Guys, I just bought a set of lowerd springs for my Bora, I should've done more research before I purchase the springs. I just need some feed back if I have to replace my shock as well or can i just use the factory shock for now?
    2009 Tiguan TDI and 2007 Passat TDI
    Apr 2008
    Firstly, be sure that the springs you got are for the 4Mo bora or the R32 Golf - ones for the FWD versions won't fit on the rear.
    You should be able to use the lowered springs as long as they don't result in your dampers hitting the bump stops.
    Nothing to see here...
    May 2009
    Canberra
    It is off 2003 4motion bora. And here is the ads for it.
    http://www.vwwatercooled.org.au/f24/...0-a-51798.html
    what you think mate?
