Hey guys
Has anyone bought spark plugs from ECS before?
Are they suitable for aus spec cars etc?
I've got a V6 bora. Just wanna make sure they'll be okay before I add them to my group buy list
Thanks for the help!
Mitch
-EDIT: Can I also ask...
Does anyone know what size standard 4mo brake rotors are? front and rear? ECS says Front 288mm/Rear 232mm? but I've read that they are really front 312mm/rear 256mm?
Check that on NGKs site. Often it means they are gapped for a particular application AFAIK.
The 11 stands for 1.1 gap
Checked the product code on ecs without the 6 and the same plugs, but a 4 pack came up with the same product number and '4' on the end
So it's all sorted. Confident they are the right ones!
Thanks
My 4mo has 312 on front
The reason it says different size brakes is due to americans only having a FWD VR6 instead of our 4mo VR6 which came with bigger brakes.
All the info you need for brakes
VWVortex.com - The brakes of the MK4 platform - OEM and Upgrades
Also i brought the same plugs from them and haven't had an issue.
2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
Yeah I've found out 4mo have 312x25 and 256x22
So found the right rotors on ECS! Lucky I didn't buy the 288's... haha
thanks for the link also
