Firstly, on the Aussie R32 the two wires are pretty well separate from the main harness in the passenger lower A pillar and are right next to the corrugated tube that runs to the back for the vacuum flapper (vacuum "supply" tube)
Secondly, there is also another thinner grey/blue wire that people sometimes cut in error, but that is actually in the main harness on ours.
The wire we want is right next to the yellow/black wire (which is the other wire running back to the solenoid). Both these wires are 1.0mm˛, so quite thick compared to some others in harness.
The grey/blue wire is actually the earth from the solenoid. The ECU earths this wire when it wants the flapper to be quiet.
Does it do anything at all at the moment - like always loud or always quiet?
PM if you are looking for: R32 rear sway bar; R32 suspension springs; Euro Headlight switches
