Page 5 of 16 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 158
Thread: dylan8 mkiv gsw tdi
  1. #41
    Jun 2011
    Awesome!
    Does this use a DBW pedal?
    All the loom was in place just needed the cruise loom from black plug under dash to wherever it ends up?
  2. #42
    Yep. No TB on this bad boy.
    Wiring must be from the ecu in to the car already? I noticed on some petrol models the loom I got has an extra wire that needs to go to the ecu. Maybe that's a dbw vs cable thing?
    This loom ran from the switch, to the rain tray, and a single wire to the fuse box for power. Fairly simple once I worked out which pin went where
  3. #43
    Nov 2015
    That green cruise control light on the dash looks great. Glad that it all came together without too much hair pulling.
    1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
    1996 Vento GL (white) - RIP
  4. #44
    Quote Originally Posted by feenix74 View Post
    Yep so happy. Racked up over 400 miles over the weekend so was used a fair bit.
    Due to the long rails I'm getting more space between the bars than the bora had. Coming in handy already
    Sent from my HTC 2PZC100 using Tapatalk
  5. #45
    Nov 2015
    Mighty handy that. I had to do something similar with my Caddy's roof rails and racks when bringing home a new solid core front door from Bunnings.
  6. #46
    Bored of driving a stock car
    Time to start getting all my good bits together.
    280 and 232mm upgrade to 334 and 256mm
  7. #47
    Jun 2011
    Big brakes for a big brick
  8. #48
    Yep. Will pull it up nicely and also slow it down a fair bit. Will just mean I'll have to make it faster afterwards
  9. #49
    I thought mk4 wagons are rare in aus
    Fixed (fingers crossed) gearbox leak and did a fluid change. After a 20min drive 3rd and 5th feel much better.
  10. #50
    Nov 2015
    Careful they are multiplying
