Page 7 of 16 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 158
Thread: dylan8 mkiv gsw tdi
  1. #61
    Cheers.
    Steers so much better with the solid arms, fresh tie rods and solid strut tops.
    Keen to get it back on daily duties for some comfort and fuel economy
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  2. #62
    dylan8 mkiv gsw tdi-imag2685-jpg
    Mounts landed. Thanks to Dean!
    I always try to upgrade when possible but poly/solid mounts are no good on the 1.9s it seems.
    Favourite combo by the UK guys is either all stock or oem gearbox/engine mounts with a firmer dogbone which is what I'll be doing.
    Hopefully can get the engine up and exhaust on now. Free up a few more ponies at same time.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  3. #63
    Jan 2011
    Gold Coast, QLD
    Nice choice. Genuine vw mounts are the only choice for stock mounts. I previously bought Meyle mounts and they were really average, lots of motor movement.
    What durometer dogbone mount did you get? The 70a version?
    Remember to get some new engine mount bolts as they are stretch bolts.
  4. #64
    What I was worried about. Forked out a few extra dollars but should be worth it long term.
    Bfi black bushes. They are the lowest rated. Have them in already and feels good.
    Yep on the cards. Scary the motor suspended like that.
    Already put new bolts in when I did the motor swap
    I have engine spacers to go in so going to use the old bolts with the new mounts to mock it up. If the mounts lift the motor enough for now I'll just replace the bolts one by one. If the spacers need to go in now I won't have wasted another set.
    My vu4 service kit has been in aus for ages now. Auspost are taking forever to get it here
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  5. #65
    dylan8 mkiv gsw tdi-imag2726-jpg
    Alignment done. Drives sooooo much better with fresh rubber (even if cheap stuff) and wheels pointing in the right direction
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  6. #66
    Nov 2015
    Excellent, glad to read that it is going well.
    Reminds me to get the red Vento of Daughter No 1 to get the wheel align checked.
    1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
    1996 Vento GL (white) - RIP
  7. #67
    Cheers! Also got myself a mk4 service manual that covers my motor in hope to learn more about the fuelling system and fix a couple of leaks.
    Got one from buddy silver dub but only covers the mk3 style 1.9tdi they put in some mk4s.
    Look after them! Seeing more and more go through the wreckers. Numbers must be down on the orginal ~450 or whatever was sold here
    Sent from my HTC 2PZC100 using Tapatalk
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  8. #68
    Nov 2015
    I will try, just wish I had more time and cash to throw at them.
  9. #69
    Got around to throwing the rears on.
    Also found a locally sold centre caps that fits, looks similar to the orginal abt ones, just need to work out how to get a vw or abt badge on them
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  10. #70
    New Osram LED number plate lights as my 42DD ones finally died after about 10years of use
    R32 airbox, maf and intake pipe sorted thanks to bug_racer. I'll give them a clean up and new air filter.
    Now just need to order mk4 r32 dsg snorkel, clean and fit my pd150 intake and upgrade the race pipe to a bigger one. Intake side of the motor should be sorted.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
