Fingers crossed will have photo evidence of 3 together soon..
Excuse the filthy car.
Finally did the rear wiper delete. Rather than do the usual trick of blocking the hose I swapped out the water pump for one with a single outlet. Save the risk of it leaking in the hatch.
Wiper was rusted on there well.
Was going to install the 5.5l washer bottle while I was there but is tight with the larger pipe work which means its going to cause issues with future setup
Also wired up my genuine Hella fogs to run as oem off the headlight switch.
Seem to be running a bit short on power so need to check out what's going on there.
Still trying to sort new headlight lenses.
4th set I've purchased arrived and they look like they have been moulded with a potato.
Horrible shapes/edges, bubbles and pitting. Wouldnt put them on pov pack headlights so no chance they are going near the Xenons
Sent from my HTC 2PZC100 using Tapatalk
