Page 11 of 16 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 158
Thread: dylan8 mkiv gsw tdi
  1. #101
    Apr 2014
    Penrith, NSW
    They came up a treat.
    RE: R32 rack, you'll need the steering angle sensor / clock spring (it's all one unit) as well. Otherwise your ABS/ESP system will give a different reading to the physical rack and throw errors. A rack out of TT or S3 I imagine would be identical to R32.
    Pretty sure I remember reading somewhere Simon stuck one in his Bora Turbo, he should have more info on this.
  2. #102
    Quote Originally Posted by beale187 View Post
    Thanks for that. Wouldnt have even thought about the angle sensor!
    Makes sense, Iv been reading how I need to connect the steering angle sensor to my Satnav to get more accurate results so should have picked up on that.
    Sent from my HTC 2PZC100 using Tapatalk
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  3. #103
    Not much to update.
    Passenger side Cv boot let go and drivers rear wheel bearing was getting loud.
    Cv boot was a easy fix, the rear was not so much fun.
    The orginal dust shield fell to pieces, not only were the caliper/carrier bolts rusty and siezed, any that had been out previously were rounded. the sensor was held in by a screw and two nuts which meant the new larger shield wouldnt fit.
    Lucky I had the old rear bean from my bora in hand so new stub Axel and hardware went in with the bearing. Bigger dust shield is in preperation for 256mm rotors
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  4. #104
    My Arosa knobs finally arrived today.
    Excuse the gauges, they'll be gone soon fingers crossed.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  5. #105
    Nov 2015
    Hobart, Tasmania
    Hey Mate, I've fitted a mk4 r32 rack to my Bora along with ckock spring, I'm still getting Esp issues. Other posts seem to suggest a whole heap of stuff that needs changing. I'm planning to haze the Esp coded out. Hope it helps.
  6. #106
    Quote Originally Posted by Gez110 View Post
    Keen to see what else is involved.
    Mine doesn't have esp to my knowledge so maybe that much easier
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  7. #107
    got some floor grommets/plugs from VW as mine were missing or toast.
    car was INSTANTLY quieter even doing the two in the wheel well.
    Strongly recommend checking them people.
    Hopefully keep the boot a bit drier too.
    Quick service, oil was much cleaner this time. The cooked turbo or whatever was going on when the motor was the previous car must have filled it with sludge.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  8. #108
    Apr 2014
    Penrith, NSW
    That's disappointing to here Steve, I'm planning on doing the same. Maybe it just needs to be re-calibrated through VCDS?
  9. #109
    Apr 2014
    Penrith, NSW
    What size brakes you plan on running on the back Dyl?
  10. #110
    256mm vented from R32
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
