Are the control arms idf ones? How much they set you back? Seems a legit thing to do to get rid of the stock lca's
so some updates...
Genuine Mercedes Segins (6 slots)
18x8et44
18x9et46
fitted here with 215/35 and 225/35
I believe these to be the only set (or one of very few) of the 18" versions in AUS (can get 17s if you look hard enough).
Was pretty keen to one day own a set when Santi ran them as 8s all round on his bora in the US back in 07/08
was trying to find another pair of 9s in decent condition to do 9s all round, but cant be bothered anymore.
being that they are staggered 8s and 9s makes them even more valuable and rare (vortex kids would go nuts)
Iv had a laugh confusing people thinking they are big bob jane chromies, then they look closer and see they are merc wheels with some fitment.
Bora 1 by Matthew Dart, on Flickr
Did anyone spot the other two sets of my wheels at the show
as you can also see I finally fitted air ride.
I first ordered way back in Nov 2011. and while I am still missing the rear struts 16months later and half the stuff that did turn up had wrong fittings (yeah i know) I only got it under way late last year.
boot setup was done end of November 2012 but I was working flat out back in bairnsdale and didnt get to touch it ill feb this year.
with much help and support from the boys we had it bagged in the rear one w.e, next weekend was the front (had to wait to get a fitting changed..)
im running 2x3gal tanks
2x444c compressors
VU4 valve block.
3/8" lines
bagyard bomber fronts
bagyard classic rear bags with TA technix struts (until my shortened bilsteins arrive from bagyard)
e-level management (sensors yet to be installed)
1x single needle (yet to be installed) and 2xdual needle anolog guages in the pocket above the head unit.
plan to add a few extra bits like replacing my electric air horn, a hose with tyre pump on the end, and some sneaky drainage to make maintenance a breeze
Some of the interior hasnt been fitted (or fitted correctly) and the boot needs a tidy up after having some electrical issues first time round.
still need to do some modifications to the car to get it lower, but that will be happening soon once the air ride gets engineered.
best part is I still have a full sized boot, I will have to raise the floor about 1cm to clear a fitting but other then that the boot looks stock as a rock.
I do have some photos of it fully aired up and down on different wheels and the merc wheels.
will have to find them
Im currently stuck on rear beam in the back. so drop plates will be sorting that out and helping me get low. plus some camber
in the front im beached on the driveshaft on the drivers side (no different to when I was static) and on the passenger side im stick on the joint between the control arm and subframe, so the IDF control arms will be sorting that and giving me some camber adjustment to match the rear (although this does effect all the offsets of my wheels and pushes them out further then before...)
A quick vid my mate Matt took of it rolling while Stu was behind the wheel after we just finished it
............ Like
Loving those wheels o your car dyl.........so baller.
Please fix that side chrome trim ASAP!
White Scirocco R
White MK3 Golf 2dr
White Caddy (Work Van)
Winnnnnninnnnnng
Soooo good, loving the wheels![]()
Cheers guys!
Yeah I know Tim... I tried to do it before ilv by straightening out the old one, but it was just too far gone to make it fit nicely.
Going to keep a eye out for a straight second hand one.
Now to decide what wheels to finish/build next and get the rest of the car back together![]()
So you planning on getting the air ride engineered? What does that involve, surely that means it can't be lowered while driving. You can only air it down when your parked? Looks so good, I need to get my arse into gear and bag mine. You've given me motivation!!
