Results 1 to 10 of 502
Thread: DYLAN8 01 Bora
    Thanks guys!!
    So 18" lips on the 17s arnt doing if for me after more research... they dont look scaled right against the centres in other pictures as others have said.
    So... new plan is:
    on the front:
    rear lip, rear centre, 15mm adapter, front barrel. this should give me a ~7.5" wide wheel. 205/45 tyre off the rear and enough offset that i could still wind the coilover right to the bottom if i wanted. Tyre will give me a bit more side wall height so i can close up the wheel arch gap without going to much lower. 205 will give me 8mm approx, 215 = 18mm approx extra tyre height
    on the rear:
    Re drill the flat backed front centre, so no adapter needed (maximum offset play), and new lips for some bigger dish, should be 9.5-10" in the end depending on what i can fit between the shock and arch.
    and most likely a 215/45 tyre for a 9.5 wheel or 225/45 tyre for the 10", then add the camber plates.
    Giving me again more tyre height, so i can hopefully tuck while still having some nice rake.
    Shouldn't work out toooo expensive as ill just need two new tyres, two new lips, refurb existing lips, and drilling cost
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Nov 2005
    sounds good mate! cant wait to see progress
    dom
    This car looks porn, why havent I seen this thread before!!
    Good work mate, clean and simple.
    Sounds like you have the wheels all sussed, cant wait for more pics
    Feb 2010
    Launceston, tas
    you car is pimping and looks heck gangster with bbs glory!!! I'm looking for RS's pretty bad right now. Where did you get yours from?
    Quote Originally Posted by Lorenz View Post
    Cos until the BBS it was boring haha? and i dunno if it should be in the picture thread??
    Thanks guys.
    undisclos3d your not the only one to ask me haha.
    I got them via a fellow forum member.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
