Hey Bert,
Sounds like the guy must have a VAG COM if he's been able to check the codes... (VAG COM is the service interface for recent Dubs & Audis - software on a laptop talks back to the computer in the car - the port is located under the removable panel beneath the stereo if you're curious)
Not too cluey on this stuff either, but sounds like the throttle body sensor is on the way out - that would trigger a faulty reading & then engine goes rough. Don't think the throttle wouldn't have it's own computer as such so making the assumption it's a sensor not reading correctly. Not too uncommon on Mk IV's
There is also a 'reset' process (throttle body alignment) which has to be carried out if the battery has been removed etc or presumably if the tb has been removed. Not sure if this is what the service report is referring to when he says 'adaption reset' ??
If it has been reset & cleaned a few times, then it probably will keep faulting. I don't think it will cause any harm though, it's just annoying. Mine's the same intermittently too.
Link to throttle body alignment info: http://www.ross-tech.com/vag-com/cars/throttlebody.html
Have a look through Ross Tech for all the other stuff you can do with VAG COM too
edit: just saw your wtb thread, hope you find one at a reasonable price![]()
