Resident grumpy old fart
One alters the other. If your radius is 1.5mm larger your diameter will be 3mm larger and your circumference will also increase and therefore will do less turns per kilometer. Normally most people refer to the Diameter when talking tyre sizes. Thats all I was meaning.
In the OP's case it wont make enough difference to matter. Lots of people use an old worn tyre for a spare and have no hesitation using it, if needed the day after putting new tyres on the vehicle. It could therefore have a difference in diameter of up to 12 mm.
Havent heard of any diffs going bang.
it's only going to be driven to work and back till 18"er get it's crack welded. 18" + 40 series tires + pothole = bent/cracked rim/$120 repair
If its a MAG rim I would recommend a read of this
Alloy Wheel Repairs
Dont know about here but it is illegal in NZ to get mags repaired in anyway at all No rolling or anything for safety reasons
