Results 1 to 10 of 18
Thread: Driveshaft rubbing against swaybar
    May 2012
    So I put Coilovers in recently and when turning hard would always hear this weird scrubbing noise. Found out tonight my drive shaft is rubbing up against my Swaybar! Is this common and is there a way I can fix this???
    Is it dangerous to drive on?
    Aug 2009
    Exceptionally common... Get a sway bar that's made for a lowered golf or raise the car.
    http://www.ecstuning.com/Volkswagen-...ay_Bar/ES2185/
    It's not too bad to drive on. Unless of course it's rubbing all the time.
    Platinum Grey mkV Jetta turbo, Viezu motorsport map, GT-CX 18", lowering to come
    Apr 2011
    Berwick, Victoria
    Looks like you've got bigger issues than the swaybar - chassis (thinner ring on the driveshaft).
    Jul 2007
    Brissy
    Some have been know to remove the sway bar completely.
    If you are hitting the chassis you may want to wind the coils up a bit, it will help with the sway bar too. Or you can notch out the chassis.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Jul 2009
    Geelong, Victoria
    or rather than change the whole sway bar, get longer drop links:
    use these:
    to replace these:
    search vw adjustable drop links on ebay, or ecs tuning have them
    My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
    Aug 2011
    melbourne
    when i get my car back from the tuners, im gonna take to that son of bitch with angle grinder
    '02 GTI (clicky) - REFLEX SILVER - VIEZU race tune. VAR design 2.5inch stainless steel dump pipe with 100cell cat into 2.5" billyboat stainless cat back, Forge TIP, N75, Audi DV, ghetto CAI, FK-AK s coilovers, tunerdone LEDs, Clarion CZ301E sound stage.
    May 2012
    How much longer are these mate?
    Do you plan on staying that height or going lower?
    If that height delete sway bar or get a new one, don't bother with end links.
    Lower, delete it completely, you won't notice it missing.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    May 2012
    oh really?? I was probably going to stay at that height...I didnt think stock swaybar would be too important. Might just remove it.
    Feb 2010
    Launceston, tas
    Cut that sucker out if your thinking about going any lower, mucking around with drop links will most likely get you nowhere. There is such thing as a swaybar that goes under your driveshaft, called a hotchkis. Never really looked into them but from reading on vwvortex they can be a solution. Cutting your swaybar does sound absolutely dodgy. I was pretty hesitant when doing it but afterwards i noticed minimal difference. But really if your riding that low your probably not going to be taking hairpin corners at breakneck speed
    Anyways! Welcome to the never ending world of problems from slamming your mk4!!! Next will be axle bind, frame notch, smashing oil pans and ripping out dog bone mounts! haha but walking out to see your mk4 sitting nicely on the ground will make you forget about all that stuff.
